Procharged efi motor in 2nd gen?
I just traded out my Big block for a 5.3 truck motor with AFR alum heads , and a pro charger setup , it spun the harmonic balancer on the crankshaft ,
So my question is , should i buy a eagle 1 crank and install (motor made 525 on pump gas and stock injectors ) or i have a 6.0 liter , that the heads , and cam will fit into , any info or advice on the two , and also the install , anyone else have any experience with installing this ? I also have all the wiring , computer and everything that goes with it .... |
id fix it.. swap in a keywayed crank.. once you get into a 6.0, then you need block, pistons, rods, crank cam.. bigger injectors.. (then perhaps a bigger blower to feed the bigger motor) bolts, gaskets and a lot of work... incliding dynotune.. that way you will have traded your running BBC for a set of used AFR heads and a bunch or 5.3 parts..
Which big block and why you go to a small block.
| All times are GMT -7. The time now is 02:35 PM. |
