-   -   BBC EFI Stuff (https://www.lateral-g.net/forums/showthread.php?t=11264)
PhilM 09-25-2007 08:12 PM
BBC EFI Stuff
All Parts are new except for the 4150 4 hole throttle body and intake. The intake and used TB are near new. You get what you see from the manifold up.
Wilson 4150 flange elbow and accufab 90 mm mono blade:
http://i202.photobucket.com/albums/a...h/P9250027.jpg
BBC Rec Port intake with fuel rails, New Aeromotive boost ref regulator, 10,000 RPM nitrous plate with tune ups from 225 to 425 hp, 4150 4 hole throttle body, and fittings, water sender and t stat housing included:
http://i202.photobucket.com/albums/a...h/P9250019.jpg
http://i202.photobucket.com/albums/a...h/P9250018.jpg
http://i202.photobucket.com/albums/a...h/P9250017.jpg
8 Lucas 42 pound injectors:
http://i202.photobucket.com/albums/a...h/P9250020.jpg
All for $ 1800 or best offer plus shipping.
PhilM 09-26-2007 08:13 AM
Will seperate.
Price is $1500 or best offer. Located near Sacramento.
bigtyme1 09-26-2007 08:20 AM
do you have the harness for the EFI?
PhilM 09-26-2007 09:00 AM
No, I do not. I have a Big Stuff 3 Controller that has its own harness. I would think that most aftermarket or stock harnesses and PCM's should work with this unit.
gmjj13 09-27-2007 12:56 PM
interested in doing some trading? let me know...
https://lateral-g.net/forums/showthread.php4?t=10914
PhilM 09-27-2007 10:48 PM
If it had the brackets, mabey. I am looking for a 700r4 for my 91 fullsize blazer and vortech heads...
gmjj13 09-28-2007 04:04 AM
thats cool. if you change your mind, let me know. later...:cheers:
