-   Paint and Body (https://www.lateral-g.net/forums/forumdisplay.php?f=52)
-   -   Mud work, Did I mess up? (https://www.lateral-g.net/forums/showthread.php?t=11282)
bigtyme1 09-26-2007 05:22 PM
All my body work is finished except the hood, today I started doing all the metal work and grinding and with out thinking I started all the mud work, Look great. But I for got about the dam epoxy. what's my chances?
68protouring454 09-26-2007 05:34 PM
no worry s, as long as its in an insulated shop its fine, either finish body work and use some etch primer on base metal areas, or epoxy, then prime. no big deal i only epoxy if i am going to use polyester primer
jake
bigtyme1 09-26-2007 05:47 PM
jake
Thanks Jake, I do paln on using Standox spray polyester once the major body work is done. Can I epoxy over the mud then spray the polyester?
J2SpeedandCustom 09-26-2007 06:20 PM
Yep. Epoxy the whole car that way the bare metal is covered as well. Then lay on the poly.
bigtyme1 09-26-2007 06:34 PM
Thanks Jake now I can sleep
