-   -   Undercarriage pics of mufflers - plese (https://www.lateral-g.net/forums/showthread.php?t=11340)
Bowtieracing 09-30-2007 08:07 AM
Hello!
Can somebody post pics of exhaust systems with flowmasters in a first gen with minitubs. My idea is to mock up mufflers to see there is enogh space and make more if theres not. Basicly the question is are the side in / center out the ones wich mounts the best ?
http://www.flowmastermufflers.com/images/_40_super.jpg
rsk68 09-30-2007 06:15 PM
https://lateral-g.net/forums/show...0040#post90040
not flowmasters but should be close enough.
Bowtieracing 09-30-2007 10:11 PM
Thank you Rick!!
I got the idea. How do you like the Vbands? Do the work on "street" ?
I was planing to use em from headers to the end.
sunset68 10-01-2007 08:13 PM
Best I got...
http://i99.photobucket.com/albums/l2...dymufflers.jpg
Bowtieracing 10-01-2007 09:51 PM
Some thoughts... or brain farts you deside:rofl:
I ordered 50 series deltaflows and plan useing them as mockups to check i there any need to make more space for mufflers. Since the car is now on body dolly its pretty easy to fab more room under the rear seat.
I want to run 3" ´system as tight as possible .
rsk68 10-02-2007 06:54 AM
v bands are high quality parts but i have not run it on the street yet.
Payton King 10-02-2007 07:35 AM
Mine is a 3 inch system all the way
back with an H pipe. It is as tight to the car as you can get it. Inlet uses offset, center on the outlet. I am running Magnaflows...they sound really good on a LSX motor. The mufflers are only 14 inches long and you can see straight through them.
Hopefully the car will be on a lift friday and I will shoot you some shots of it coated and complete
