Paint Booth
Used CrossFlow Booth draws fresh air through filters in the drive in doors. This clean filtered air is pulled through the booth and then exhausts through a filter system on the other end.
The BECF-1000 model has filters across the center portion of the back wall. The filtered exhaust air is pulled through the exhaust plenum and discharged straight up and into the atmosphere through an exhaust stack. 8'4" high x 10' wide entrance doors 20'3" long x 12'9" wide x 8'4" high interior dimensions 23' long x 13" wide x 8'10" high exterior dimensions 24" fan with 3-phase - 2 hp motor with belts, pulleys and sheave All 18 gauge galvanized steel construction All hardware, fasteners and sealants 16 - 20" x 20" intake filters and exhaust fans 6 - 48" 4-tube light fixtures with clear tempered glass Personnel door Assembly instructions/permit package Draft Gauge UL approved components Selling for a friend less than 1 1/2yr old. In Miami. Can deliver all the way to Tennessee for additional fee.... $2799 http://www.racingjunk.com/post/98372...NT-BOOTH-.html |
| All times are GMT -7. The time now is 10:56 AM. |
