-   Transmission and Rear End (https://www.lateral-g.net/forums/forumdisplay.php?f=39)
-   -   6 speed behind a 455 poncho help. (https://www.lateral-g.net/forums/showthread.php?t=11477)
Ummgawa 10-08-2007 07:52 PM
I may have asked before, but does anyone here have a source for a bellhousing to bolt to a 455 or any pontiac block so I can run a 6 speed behind it? I have tried Weir products but he is "in casting mode", so no luck. Any other suggestions? The 6 speed is from a 2002 Z-28.
Thanks in advance.
Mkelcy 10-08-2007 09:18 PM
Call McLeod's tech line. Their modular bellhousing should do it.
chicane 10-08-2007 09:21 PM
McLeod modular bellhousing P/N: 8710-10 // http://www.mcleodind.com/application...L_HOUSING.html
Pictured at the bottom of this page: http://www.mcleodind.com/downloads/p...DFs/Page_9.pdf
COYBILT 10-08-2007 11:14 PM
the mcleod bell housing should be the ticket on this one.
Ummgawa 10-09-2007 05:29 AM
Most excellent, Thanks!!
Jimmy Sean 10-09-2007 06:05 AM
With the mcleod bell housing do you use a mechanical linkage or the LS1 Camaro hydraulics?
Mkelcy 10-09-2007 06:38 AM
If you swap out the "front intermediate plate" (that's what Tremec calls it) on the T56, you can use a mechanical linkage with the modular bellhousing. The substitute intermediate plate has a provision for a clutch fork pivot. If you don't do the swap, you use the LS1 hydraulic linkage. McLeod manufactures and sells intermediate plates - about $320 through Summit.
