Twin turbo System for 69 Camaro
3 Attachment(s)
Twin turbo set up for SBC built to fit 69 Camaro.
includes; -Two borge warner 66mm extended tip turbos -Stainless headers and down pipes, for out side frame rail exhaust(side exit) -Two custom built water to air intercoolers -Heat exchanger and pump with all the hoses. -Aluminum charge tube -Two tial BOV's -Two tial 46 mm waste gets -Modified core support and inner fenders included.(intercoolers are mounted to core support) -B&B baffled, w/ crank scraper, oil pan with return bungs welded in, included -All oil feed and return lines as well as boost refrence lines included. In testing these two turbos made 1257hp on a 377 test motor @ 23 psi non-intercooled on c-14. This system is capable of 1200 hp on pump and over 1400 on c-16. System has only been installed and never run, all components are new. It does fit under a stock type glass hood, or modified steel(under support). We had it off for a car show. Please e-mail me or call if interested....231.739.5484 Please serious inqueries only....selling less than new price. Thanks Andy |
Nice setup. You'll need to post a price per forum rules..
15,000.00 or best.....sorry for any inconvience
15,000 for just the turbo kit or the whole motor to?
No motor included....there is all most 15,000.00 just in this system. not to mention a bit more than that in the motor. |
13,500 firm shipped to lower 48.
10,000.00 new price for new year!
| All times are GMT -7. The time now is 07:55 PM. |
