TPiS Miniram / 58mm Throttle Body
3 Attachment(s)
Went a different route with my new engine and have this Mini Ram for sale;
It is a Miniram-I and was designed to be used on pre-LT1 engines. It is ported to a 1205 gasket (plenty of room to go to 1206) and has a set of high-flow fuel rails, throttle cable bracket and a 58mm throttle body as you can see in the pictures. Asking $800 Plus Shipping Additional info; 1. Has it been used before, on what? This manifold was on a 750hp (dynoed) 435" small block with Dart Heads - All throttle - no power adders. It should work on darned near anything you want to build. 2. Do you have any pictures of it that you can send me? Yes - just ask and they will be sent 3. Does it have fuel injectors and/or fuel rails? Yes it has fuel rails from TPiS. The Fuel Rails have been modified with a -8 cross-over line and AN/JIC fittings. There are no injectors with this - they were used on another engine. They were 42#. 4. What other things does it come with, sensors, water neck, bolts etc.... The Throttle Body - 58mm - I was told that it was TPiS, but I think it is probably a Lingenfelter. There is no IAC motor on this TB so you will need to use your own from any GM V8 Throttle body. The Water outlet neck (T-stat housing) has been modified appropriately and included. There is also a custom made Throttle Cable bracket made of Aluminum and would look very nice if polished up. 5. It has not been milled and is in very good condition - just a little dusty from sitting around in my shop (boxed). This manifold has not been modified for the angled center bolts (some late model heads use these) - but there are very shallow reliefs cut into the side of the plenum to allow the center bolts to clear. If you don't have these reliefs you can only install a 1.25" bolt in the center holes and you will not get a good bolt depth into the head. |
pm sent
PM Returned
Still available...
SOLD... Thank you!
| All times are GMT -7. The time now is 11:53 PM. |
