-   EFI and Forced Induction (https://www.lateral-g.net/forums/forumdisplay.php?f=47)
-   -   Tpi??????? (https://www.lateral-g.net/forums/showthread.php?t=12636)
jamescarrell 12-22-2007 07:18 PM
Tpi???????
I just got a 1973 Pontiac Ventura that has a 350. I was wondering, does anyone knows if a TPI intake off a vette or camaro would bolt on? I was also wanting opinions on the TPI engines.
98ssnova 12-23-2007 11:10 AM
It should depending on the year of the block I think you need and 86 and up or a set of vortec head but then again I have been wrong hope this helps
907rs 12-23-2007 10:28 PM
If it's a pontiac 350, the answer is no.
aany001 12-25-2007 09:30 AM
The TPI unit will fit but you have to use a 85 or 86 unit.I have a 86 corvette complete unit if your interested that will bolt directly to your engine as long as your rocker covers/cylinder heads are outer edge bolt style and not the centre hold down style this set up will bolt up perfectly to your engine.
