FS: Comp Cams Drag Race Solid Roller Camshaft--Almost New
Cam Has Only 5 Dyno Pulls on It Small Block Chevy V8, 262-400, 1955-1998 DRAG RACE Mechanical Roller Camshaft 5,000 Stall / 11:1 Compression A cam designed for nothing but racing. If you're looking for more than just a streetable cam, COMP Cams has designed a drag race cam for you. These cams are designed specifically for all-out drag strip performance. Summit Racing Part Number# CCA-12-906-9 Cam Style: Mechanical roller tappet Basic Operating RPM Range: 4,500-7,500 Intake Duration at 050 inch Lift: 276 Exhaust Duration at 050 inch Lift: 284 Duration at 050 inch Lift: 276 int./284 exh. Advertised Intake Duration: 312 Advertised Exhaust Duration: 322 Advertised Duration: 312 int./322 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.630 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.630 in. Valve Lift with Factory Rocker Arm Ratio: 0.630 int./0.630 exh. lift Lobe Separation (degrees): 107 Intake Valve Lash: 0.020 in. Exhaust Valve Lash: 0.022 in. Computer Controlled Compatible: No Grind Number: CS 312A-R7 Notes: Requires upgraded gear, thrust button, and wear plate. Cost Me $330 Shipped New from Summit Racing My Loss Is Your Gain $175 Shipped http://img.photobucket.com/albums/v7...s/SD531182.jpg http://img.photobucket.com/albums/v7...s/SD531181.jpg http://img.photobucket.com/albums/v7...s/SD531180.jpg |
Sold!!!!!!
| All times are GMT -7. The time now is 07:19 PM. |
