| jkade72 |
01-23-2008 05:17 PM |
1967
Body: This truck is one that you always wish to find with a body that is straight and little rust. I think it may have three or four small dings on the whole truck and I mean dings not big dents. Bottom of the doors have in my opinion minor rust that is in the bottom back corner on both doors. Rockers are in good shape and shouldn't need replacing and the cab corners are in good shape. Floor pans are in good shape. Has a little rust above the passenger door on the cab, nothing major as the windshield frame is good. Naturally the battery got the bottom of the front fender on the inside, that is to be expected. The core support has the normal below the battery tray. Will need new wood for the bed since it is the original. Inside of tail gate and fender tubs are nice with little wear. Basically fix the door bottoms, place above passenger door, front fender bottom, and the core support and have a rust free 67. The paint is over 17 years for sure since the man I bought it from had it that long and he said it was painted when he got it.
Suspension: Has 72 front arms and drilled and slotted rotors with new pads from gm, 2.5" drop spindles with cut springs. Has a 72 rearend with new eaton posi, new 3:73's, glocks rear impala brackets, with drilled and slotted rotors. I have not c notched the rear yet and it will probably need it if you wanted to keep it this low but I drive on good roads and don't have any trouble. 20x8 with 245/40/20's on front and 20x10's with 295/40/20's on back and tires are still good.
Interior: Has 72 door panels that are nice as you will find, some di{k cut the bottom of the doors and put speakers there and the dash has been cut for a new style radio also. All autometer pro comp electric guages with a craptastic covan guage cluster. It has a van tilt with a chrome aluminum steering wheel.
Engine: 99 4.8 bored to 5.7 and all ls1 internals. LS1 intake, patriot 226/226-585/585 cam, ported and polished 4.8 heads with new patriot dual gold springs good to .660lift, new valve seals, new gm lifters, ported ls1 oil pump, all new bearings, mac mid lenght f-body ceramic headers, new 130 amp alt, new idles and belt. Has a walbro 255 inline pump with a vette filter/reg. Has all new 2.5" exhaust with stainless magnaflows, and a h-pipe. THe trans is a rebuilt gm unit with less than 15k miles, new fuddle 3200 stall. Has a 98 f-body harness and computer, and f-body dual fans and radiator.
Take this truck fix the minor things, fix the small amount of rust, paint, wood bed kit and I will sweeten the deal for the interior. Give me $12500 and I will throw in the buckets, console, dash pad, and door panels from the blazer. I will get it out this weekend and take some new pics for everyone.
NO LOWBALL OFFERS!!!!!!!!!!!!!!!!!!!!!! And No Trades
