1969 Pro Touring Project CAMARO
5 Attachment(s)
1969 Camaro Project for sale- All Body Is Done A Completly New Front End sheet Metal And Suspension Marqez Taillights And Hood Hinges .lots Of Mods --shaved Driprails Door Handles And Locks, Mirrors And Marker Light Brand New Tubular Front Suspenion Including Brakes And Sway Bars Etc. Also New Doors And Trunk Lid And A New Gm Spoiler. Narrowed Aluminium Gas Tank Stock Glass 4 Inch Fiberglass Hood Smoothed Inside All Sheetmetal Is Goodmarked -- Car Is Minitubbed --- FEEL Free Too Call Me And Leave Message 267-718-5349
$22,500.00 OR MAKE OFFER ----- I AM LOCATED IN PA FOR MORE PHOTOS LET ME KNOW AND I WILL EMAIL THEM TOO YOU ALL REPLACEMENT PANELS ARE MANUFACTURED FROM GOODMARK - NEW FULL QUARTERS - NEW FRONT INNER FENDERWELLS - NEW DOOR SHELLS - NEW REAR OUTER WHEELHOUSE - NEW MINITUBB INNER WHEELHOUSE --DETROIT SPEED MINITUBB KIT - NEW FRONT LOWER VALANCE - NEW DASH PANEL - NEW COWL VENT PANEL - NEW HOOD LATCH SUPPORT - NEW HEADER PANEL - NEW 4 INCH COWL INDUCTION HOOD W/ SMOOTHED UDERNEATH - NEW FENDER EXTENSIONS LOWER - NEW RADIATOR CORE SUPPORT - NEW FRONT FENDERS - NEW TRUNK LID - NEW GM SPOILER - NEW FRONT BUMPER - NEW REAR BUMPER - ALL GLASS- FRONT, REAR , DOOR AND QUARTER - NEW SOFT SEAL TRUNK WEATHERSTRIPPING - NEW SOFT SEAL DOOR WEATHERSTRIPPING - NEW SOFT SEAL ROOFRAIL WEATHERSTRIPPING - USED HOOD RELEASE LATCH - FRONT WINDOW MOLDINGS - REAR WINDOW MOLDINGS - NON TILT STERRING WHEEL - B & M BILLET SHIFTER - BILLET HOOD HINGES - BILLET MODERN TAILIGHTS W/ REVERSE LIGHTS - ALL INTERNAL HARDWARE FOR WINDOWS - NEW STAINLESS NARROWED GAS TANK W/ STRAPS AND NEW SENDING UNIT - WIPERS - REAR SEAT - CHROME FENDER BRACES - NEW KONI REAR SHOCKS - NEW STAINLESS STEEL TRANS LINE ( TH400) - STOCK DRIVESHAFT - 12 BOLT GM POSI DIFFERENTIAL W/ 4.10 GEARS --- FRONT CLIP IS A TOTAL COST INVOLVED FRONT END --- TCI Front suspension clip features double rail, mandrel-bent design that provides superior strength with higher durability. Engine mounts, core support, body mounts, and suspension brackets come installed. All heli-arc welded for highest quality strength and finish available. Engine mounts are designed to accept small block, big block and LS1 engines (optional brackets and Camaro oil pan required with LS1). Bolt-in position transmission mount is included. Urethane bushed tubular A-arms, spindles (2" drop), new power rack and pinion gear, transmission mount come standard with kit. Show package features: polished stainless A-arms, chrome spindles, chrome steering arms, chrome anti-roll bar, polished billet coil-overs, and custom 11" brake with polished billet calipers and polished backing plates. - DOOR HANDLES SHAVED - DOOR LOCK SHAVED - TRUNK LOCK SHAVED - ALL MARKER KIGHTS SHAVED - DRIPRAILS SHAVED - ALL ENBLEMS AND MOLDING HOLES SHAVED - ASH TRAY SHAVED - ANTENNA SHAVED - TRUNK FLOOR SMOOTHED - FIRE WALL SMOOTHED - ROLL CAGE W/ SMOOTHED WELDS - FRONT LEAFSPRING MOUNTINGS ARE MOVED INWARD 3 INCHES - OFFSET SHACKLES W/ 3 INCH DETRIOT SPEED AND ENGINEERING DROPPED LEAFSPRINGS - REAR WILWOOD DISC BRAKES PART # 140 -7141DP -- 12 INCH ROTORS DRILLED AND SLOTTED W/ CHROME CALIPERS ALSO HAVE 454 BB CHEVY ENGINE FOR SALE SEPARATE |
send me pics and more info to [email protected]
called and left a msg... still trying to get pics from you
69 pt project
left you a message
car is sold jamie -------- mini69 |
