New split lock header bolts from Percy's
Now available from Percy's!
The Split Lock TM Friction Lock Fastener design uses a locking set pin built in to the bolt, When tightened the set pin expands the bolt threads against the thread wall providing an unmatched lock. The Split Lock TM Friction Lock Fastener is the only fastener that provides a locking system without using any additional wires, locking compounds, lock washers or complicated interrupters. EASY INSTALLATION Install the Split Lock TM as you would any other standard bolt, the only additional step needed is to simply use a high quality hex key allen wrench to tighten the set pin to lock the fastener in place. This action locks the bolt and the set pin in place so you can rest assured that the bolt will not loosen due to Vibration heat or torque dependence. EASY REMOVAL The Split Lock TM can be removed simply by loosening the set pin and backing out the fastener. USE THEM TIME AND TIME AGAIN These fasteners are made of only the finest alloys allowing the same fastener to be used over and over while providing the same locking ability time and time again. Available in black oxide or high strength stainless, same quality stainless as found in ARP bolts. Pricing starts at $54.99 for certain black oxide kits and goes up to $139.99 for certain stainless kits. Application list below: SPLIT-LOCK FASTENERS - HEADER BOLTS - BLACK OXIDE 20001 SB GM / BB CHRYSLER / AMC V8 QTY 12 3/8”X3/4” 12POINT 20002 BB GM / SB & BB FORD QTY 16 3/8”X¾” 12 POINT 20003 SB GM / GM V6 (2.8L) / BB CHRYSLER / AMC V8 QTY 12 3/8”X1” 12 POINT 20004 BB GM / SB & BB FORD QTY 16 3/8”X1” 12 POINT 20005 SB CHRYSLER QTY 12 5/16”X ¾” 12 POINT 20006 SB CHRYSLER 1" QTY 12 5/16”X1” 12 POINT 20007 DODGE VIPER V10 QTY 24 5/16”X1” 12 POINT 20008 GM GEN III LSX / FORD 4.0 V6 QTY 12 8MM X 25MM 12 POINT 20009 FORD 6.8L V10 QTY 24 8MM X 25MM 12 POINT 20010 FORD 4.6L 5.4L / GM 8.0L QTY 16 8MM X 25MM 12 POINT SPLIT-LOCK FASTENERS - HEADER BOLTS - STAINLESS STEEL 21001 SB GM / BB CHRYSLER / AMC V8 QTY 12 3/8”X3/4” 12POINT 21002 BB GM / SB & BB FORD QTY 16 3/8”X¾” 12 POINT 21003 SB GM / GM V6 (2.8L) / BB CHRYSLER / AMC V8 QTY 12 3/8”X1” 12 POINT 21004 BB GM / SB & BB FORD QTY 16 3/8”X1” 12 POINT 21005 SB CHRYSLER QTY 12 5/16”X ¾” 12 POINT 21006 SB CHRYSLER 1" QTY 12 5/16”X1” 12 POINT 21007 DODGE VIPER V10 QTY 24 5/16”X1” 12 POINT 21008 GM GEN III LSX / FORD 4.0 V6 QTY 12 8MM X 25MM 12 POINT 21009 FORD 6.8L V10 QTY 24 8MM X 25MM 12 POINT 21010 FORD 4.6L 5.4L / GM 8.0L QTY 16 8MM X 25MM 12 POINT SPLIT-LOCK FASTENERS - BLACK OXIDE - COLLECTOR BOLT KITS 20100 COLLECTOR BOLT KITS QTY 6 3/8"X 1" 12 POINT W/ NUTS SPLIT-LOCK FASTENERS - STAINLESS STEEL - COLLECTOR BOLT KITS 21100 COLLECTOR BOLT KITS QTY 6 S.S. 3/8"X 1" 12 POINT W/ NUTS |
| All times are GMT -7. The time now is 09:10 AM. |
