-   -   JFZ big brake calipers (https://www.lateral-g.net/forums/showthread.php?t=14427)
sacarguy 04-07-2008 10:05 AM
jfz big brake calipers
set up for 13 inch front 12 inch rear rotors
These calipers are still suported by siera brakes who bought out JFZ so parts are no problem to obtain and the mounting ears are interchangable with willwood brackets so if willwood sells brakets for the car then you can put these on it with the corect ofset rotor..
Or you could simply buy 13 inch frotn 12 inch rear rotors for your car and make your own mounting brackets
they are absolutly masive aluminum calipers
currently painted black they could easily be show polished or have your own logo etc milled into the side for a realy unique setup
asking 450 for the set of four calipers
you can easily use these to build your own huge brake kit for your project.
http://i76.photobucket.com/albums/j1...f/DSCF0565.jpg
http://i76.photobucket.com/albums/j1...f/DSCF0566.jpg
http://i76.photobucket.com/albums/j1...f/DSCF0567.jpg
