4L80E first gen install??
Anyone know what is involved to install a 4L80e on a 68 Camaro?? I had planned on running a T56 but I stumbled across this 4L80e and debating on running it........just dont wanna regret it later!!! I have a 454 mark V without the injection right now, nothin to special just beefed a little bit??
I'd be interested in the same info. I am considering a 4L80E with Trans controller and paddle shifters. I been taking auto classes at a local JC so rebuilding my own trans sounds appealing and so much less than a 5/6 speed conversion (I have a 700R4 in it now).
You'll some sort of a trans controller to run the trans, and for the ultimate fun a paddle shifter like mentioned above from Twist Machine. Jody |
Remove the adapter fittings for the trans lines and put in 45 degree #6 an 1?4 pipe fittings with a short connection hose. Then it fits real nice.
Do you have to run the TCI computer with the Shrifter or is it compatible with other programs??
Jody |
Thank you for the info............I have been very impressed with all the knowledge floating around on this site!!!
| All times are GMT -7. The time now is 02:35 PM. |
