-   -   PT Mustangs and Old Fords. (https://www.lateral-g.net/forums/showthread.php?t=14632)
fordsbyja 04-21-2008 10:24 PM
I was reading the post about PT Mustangs and wanted to add my $.02.
http://https://lateral-g.net/foru...d.php4?t=14574
Hopefully this will stay on track as the last thread started off good then went to ****.
I have a 64 Falcon I am working on. The biggest problem with Fords is the selection of aftermarket suspensions.
You have your basic MII but who wants to put 38 year old technology on their 40+ year old car? (The lower budget crowd I guess).
You next option is modifying the stock stuff and that is where I am. I still sucks after just not as bad as original. My 73 Pinto handles better so.... You can also spend a fortune on TCP or equivalent but it is still a modified stock design.
For those with big budgets you can get Griggs or some of the other custom setups but like I said they are big bucks and a lot of work.
Everybody and their dog makes Chevy front clips and they all bolt in. You can get spindles, different width A arms, big breaks, whatever you need and bolt it on. No wonder they are way ahead of the pack.
The craziest thing ever is that lately I have been having trouble buying parts. I ordered some 345-18's BFG's for the back and got 345-15's. That seemed to take a month to rectify and I never did get any tires. BTW stay away from TDPerformance.com. So then I tried to order a Griggs GR350 torque arm setup, talked to John and he said to email all the particulars and I never heard back. So then I bought a T56 from a guy in Vegas and UPS smashed it to crap breaking the bellhousing and yoke. I am currently trying to get that straightened out.
http://f10.putfile.com/thumb/8/22720152659.jpg
Vintage Venom 13" Cobra R kit with 98 Cobra R wheels.
http://img2.putfile.com/thumb/4/11201094395.jpg
http://img2.putfile.com/thumb/1/2118450722.jpg
Northern Radiator cross flow radiator with 94/95 Stuart Components water pump. Custom bracket for 140A alternater.
http://img2.putfile.com/thumb/1/2118450819.jpg
andrewmp6 04-22-2008 03:19 AM
Have you looked at http://www.rrs-online.com/ this should fit your falcon http://www.evolutionmsport.com/evmCa...products_id=49 and same with http://www.lateral-dynamics.com/products/ same as http://www.maxgsystems.com/presenter...key=Max-G-Home http://www.ajeracing.com/64-70Mustang.php http://www.fatmanfab.com/catalogpage.php?page=20 http://www.fatmanfab.com/catalogpage.php?page=21
http://www.fatmanfab.com/catalogpage.php?page=22
hope thats enough links for you
JohnnyGMachine 04-22-2008 09:07 AM
I've also talked with Kevin Doyle at Global West about suspension parts for vintage Ford muscle. Give Kevin or one of the guys at Global West a call to see if they have anything for your application.
John
fordsbyja 04-22-2008 11:39 AM
I'd really like to get rid of my shock towers in the process. Global as well as TCP, RRS and Fatman all use the shock tower. AJE is coming out with a front clip but he is not geared to towards turning corners. Griggs uses a small tubular shock mount so I will prob go that direction. The GMax rear setup looks pretty sweet. I have read good things about the Satchel link but have never used one.
Travis77 04-22-2008 11:31 PM
Also you may look at JME enterprises.
andrewmp6 04-23-2008 03:00 AM
rrs coil overs will let you notch the shock towers pretty good. The boss 429 mustangs they pushed the shock towers out they look almost like what Griggs does. But i never got to see the front suspension they used tho.Why you need to remove the shock towers for what you putting in it.
fordsbyja 04-23-2008 12:26 PM
I am just going to run a small block but my 289 headers already hit the shock tower now and I would like to eventually put in a windsor though. Besides the increase in driveability I am after the clean open look.
sacarguy 04-23-2008 02:01 PM
go m2 if you wana ditch the shock towers
just use a heidts mustang 2 ifs get rack and pinion steering and big brakes in the same deal at the same time.
andrewmp6 04-24-2008 08:49 PM
Your headers shouldn't hit them like that unless its the wrong headers or the shock towers have moved in some which happens over time.There was a couple 65 mustang fastbacks with the cammer in them and they removed the shock towers fully i wonder how they did it.This was done in 65 so couldn't been a mustang 2 kit.I'm sure theres a way but mustang 2 kit or notching the shock towers is the only ways i see.Theres other ways but they get pricey fast.
