LS2 vs. LQ4
What are the main differences in the LQ4 and LS2 besides the metallurgy of the block?
Big difference in price too. Plus with the 4" bore you can put the L92 heads on it. Car Craft did an LQ4 with L92 heads and got 550hp for less than $5000. They probably could have saved a little more if they had foregone the carb setup and did the L76 intake kit. Below is the two part story from CarCraft.com.
http://www.carcraft.com/projectbuild...ock/index.html http://www.carcraft.com/techarticles...ads/index.html |
What accessory drive will you need in order to run on a 1st gen Camaro? Will the LS1 accessory drive bolt directly to it with no mods?
Chris |
If I want to run EFI, can the stock LQ4 computer handle mods such as the L92 head swap and mild cam upgrade or will I need to go aftermarket?
Thanks, Chris |
http://www.sdparts.com/product/12590...L76L92Car.aspx For $556 you get the manifold, fuel rails, 40lb injectors, and 90mm throttle body. It's a phenomenal deal. Almost makes me wish I had gone LQ4 instead of LS1. |
They both have a 4" bore. |
And some of us running ~600 NA with a stock ls1 ECM:_paranoid |
| All times are GMT -7. The time now is 03:10 PM. |
