Fine Tuning GMPP Motor...........Please offer up some advice
Ok first of all here's the combo: GMPP 350H.O. 330hp out of the box.. mods include Comp Cams XE274 (230/236* at 0.050, and 0.487/0.490-inch lift, 110-degree lobe separation), Vortec heads milled down about .025 + thin fel-pro head gaskets(compression is close to 10:1), studs and corresponding Comp springs installed, stock HEI distributor/MSD High-Voltage Module with built in rev limiter set at 6000rpm, has 1-5/8" Long tubes into x-pipe and 2.5" dynomax bullet duals. '97 T56 6 speed and 4.10s. Currently has a 1405 600cfm Edelbrock but I have a 1407 750cfm Edelbrock waiting to go on. I am trying to get it dialed in and I have a few questions...
1.) What should I set the timing at? It's only adjusted by sound right now..It's pretty close but I am going to put a light on it to get it perfect. 2.) I have a distributor advance curve kit with three different sets of springs. Which set should I run? 3.) The 750 carb came with an assortment of primary jets, secondary jets, metering rods, and step-up springs. A performance tune for a 750cfm out-of-the-box is as follows Primary Jets - .113, Secondary Jets - .107, Meterings Rods - .071x.047, with an Orange step-up spring. Should I set it up like that to start off or change something? 4.) Any other suggestions are greatly appreciated! I am shooting for high 12s with slicks when I go to LaRue on May 30th. Thank You |
Tuning
79,
Start by setting the curve on your HEI....is that the one that came with the engine? If so that has MSD's advance set up in it so that's a good thing! Start by installing the black 18 degree bushing with the 2 light blue springs and getting initial about 16 to 18 degrees to start. I'm not afan of the E-carbs but start with the 750 out of the box and hook a vacuum gage to a small full source and tune both screws to get the highest vacuum reading. |
| All times are GMT -7. The time now is 12:42 PM. |
