-   -   '98+ S10/Blazer spindles (https://www.lateral-g.net/forums/showthread.php?t=1530)
Supercharged 86 08-10-2005 10:06 AM
I'm getting a pair for myself from a local junkyard. They said they had 3 pairs so that leaves two left if anybody is interested.
They're '98+ so they come with the hub assemblies instead of wheel bearings and the spindles are set up for dual piston brakes from GM so there is more room for the bracket to use the caliper of your choice. Well, I think a lot of you know why these are good spindles for brake upgrades. I'll be using them on my '86 El Camino and I know they fit 78-88 A/G bodies, but I've heard they can be used on many other cars as well.
The yard wants $150 a pair because they come with the hubs. They aren't sure of the milage. These are hard to find for less as I found out. If anybody else would like me to grab them a set let me know.
