-   -   I have a very nice 383 for sale (https://www.lateral-g.net/forums/showthread.php?t=15536)
Mkelcy 07-06-2008 01:13 PM
465 hp 383 SBC For Sale
1 Attachment(s)
I have a very nice 383 for sale. The engine, which was used for about 1,000 miles, is balanced and blue printed; 010/020 block, cleaned, magged, honed and zero decked; billet splayed four bolt main caps installed on three center main bearings and line bored; 4340 Eagle 3.75" forged crank; 4340 Eagle 6.0" forged "H" Beam rods; SRP –16cc forged dished pistons; Clevite 77H bearings throughout; Melling high volume oil pump with welded on pickup; Moroso trap door 7 qt. oil pan and windage tray; Crane 119841 hydraulic roller cam (0.539"/0.558", 296/304;112 LSA), double roller timing chain; Comp Cams Pro Magnum retrofit hydraulic roller lifters; Comp Cams pushrods; Comp Cams Pro Magnum 1.5 roller rockers; AFR 195 aluminum heads angle milled by AFR to 59cc chambers and assembled by AFR with + 0.100 valves and AFR 8032 hydraulic roller valve springs; Edelbrock Vic Jr. intake; Demon 750 Carb; Fluid Damper harmonic balancer; MSD billet distributor; aluminum timing gear cover and polished aluminum valve covers; professionally assembled by JMS Racing Engines in Monrovia, CA. Dyno'd at 465 hp at 5,700 rpm; 464 ft. lbs. of torque at 4,500 rpm.
This engine is ready for a turbo or supercharger with a swap of 72cc or so aluminum heads. The bottom end is more than stout enough and the -16cc pistons will get you into the right static CR range for the boost. As it sits, the engine is 10.3:1 static CR and about 7.5 DCR.
$4,500 OBO (which is a smoking deal - just add up the parts). I need this engine gone. Local pickup in Southern California. The engine is in Altadena, California. The headers are NOT included.
https://lateral-g.net/forums/atta...1&d=1215375152
JethroSeven 01-25-2010 10:29 AM
383 for sale
Hello, i'm interested in this for my '68 camaro and in SoCal. i can be reached at 310 218 8007 if you still have it. thanks J7
jwalk 01-26-2010 06:26 PM
I would jump on this if I had a little more money lying around. If you still have it in a month I might have enough.
Mkelcy 01-26-2010 06:41 PM
LOL, if I still have it in a month, I'll be giving you a call.
jwalk 01-26-2010 08:31 PM
sounds good
Mkelcy 01-29-2010 11:25 AM
Bump.
madcarson 10-09-2010 12:33 AM
Afr
want to sell the head ?:cheers:
sn75 10-14-2010 11:35 PM
That engine is in my car now :unibrow:
