Anyone used the SSBC or CPP 2" drop Spindle on GM A Body
I'm looking for a 2" drop spindle for my 72 442 and found that these were the least expensive. The CPP are $249 and the SSBC are $199 (Anyone found them cheaper)? Has anyonme used either of these or know if 1 is better than the other?
I've seen the CPP spindles in person. Very nice looking stuff. If I end up sticking with the stock spindle setup, I plan to use them.
Well, obviously ATS is the best but is not cheap. Lots of engineering in that piece.
We have been using / selling Ride Tech spindles which are tall also so you get the al important camber correction these car so need. The others you mention I have not used. |
| All times are GMT -7. The time now is 10:02 AM. |
