-   -   Power Steering Reservoir (https://www.lateral-g.net/forums/showthread.php?t=16433)
Impala TT 09-08-2008 06:59 AM
Looking for a remote reservoir with 2 return bungs, Does anyone have one available?
Thanks,
Brent
bentfab 09-08-2008 07:50 AM
Why with two return bungs? Are you running a hydroboost? I'am curious?
Mark
Impala TT 09-08-2008 08:18 AM
Yes I am running a hydroboost.
Brent
Vegas69 09-08-2008 08:28 AM
You could use a Y connector.
Impala TT 09-08-2008 09:14 AM
My understanding is that with a Y connector you get turbulence between the steering return and the Hydroboost return due to the fact that they have different prssures.
Brent
camcojb 09-08-2008 10:31 AM
Brent
just add a bulkhead AN fitting in your reservoir up high. That's what I and most others are doing, works great.
Impala TT 09-08-2008 11:10 AM
Who's reservoir are you using? Billet Specialties has the return tube inside so is it O.K. to add another bung?
Brent
slenning 09-08-2008 11:36 AM
1 Attachment(s)
I used the SR-102 from http://www.pscmotorsports.com/
camcojb 09-08-2008 01:17 PM
Brent
mine is the factory late-model pump with reservoir on the pump; there is one return line in the side and I drilled and added a second to the back up top near the cap.
Impala TT 09-08-2008 01:50 PM
Thanks Steve, i just ordered one from them. Are you autocrossing in S.Falls this weekend?
Brent
