Misc Parts - Vette - Fbody - TBSS
House is filling up with Nova/Pro-Touring parts. Need to make room.
Whisper lid replacement "LS1" stickers (8) - $3.00ea http://www.johnbrown.net/images/forsale/LS1stickers.jpg LS1 Carbon Fiber valve covers w/coil brackets - $475.00 http://www.johnbrown.net/images/fors...vecovers2s.jpg LS1 Head Gaskets: 12558809 - in original package - $30.00 http://www.johnbrown.net/images/forsale/gasket2s.jpg 12498543 - Passenger side only - $15.00 http://www.johnbrown.net/images/forsale/gaskets.jpg LS1/LS6 Z06/Truck 85mm MAF - Mass Air Flow Sensor - $85 LS1 F-body Stuff: QA1 Springs (35-OED-315-S) Used - $75.00 http://www.johnbrown.net/images/forsale/QA1springss.jpg BMR QA1/Hal Spring Cups (New) - $50.00 http://www.johnbrown.net/images/fors...pringcupss.jpg BMR QA1/Hal Shock spacers (New) - $30.00 |
just wanted to let you guys know that john is super nice guy, great seller.
I love the valave covers.. Will that oil pan work with a lsx swap on a f-body john? |
Like said above, the pan will hang a little lower than the subframe if you are using conventional mounting plates. This is the pan that BRP sells for use with his kits. |
Does it need to be modified to fit a first gen camaro similar to the f-body pan?
Mike Quote:
Reckley,
No, not if it's the same one that BRP is selling. |
I checked out BRP and it looks like they include windage tray as well. Is the windage tray GM's or is it something BRP makes? Mike |
I so miss my formula!!! went to track yesterday and it was hard to watch the other guys.
anyway, if the pan is still with you in a few weeks, I'll take it. |
John
can I just use the stock windage tray from the f-body? I sold the capri last night, so I came into a little cash..:thumbsup: |
| All times are GMT -7. The time now is 04:13 PM. |
