-   Transmission and Rear End (https://www.lateral-g.net/forums/forumdisplay.php?f=39)
-   -   Powder coating the transmission (https://www.lateral-g.net/forums/showthread.php?t=17109)
rich-allen 10-21-2008 07:54 AM
My transmission was just completed by D&D Performance, it doesn't look near as good as I thought it would so I'm considering putting a clear or light gray color powder coating case.
Can I do this without disassembling the trans?
If not, does anyone have any ideas on cleaning it up to look new and preserving the look?
I was thinking maybe sand blasting the outside then spraying a clear over it.
Any ideas would be greatly appreciated.
SOMMERSRACING 10-21-2008 08:28 AM
I would not sandblast the trans since it is done. Could void any warranty. The case should have been bead blasted when apart. I think the best thing you can do now is tape it off real good and wire wheel the case. Find a silver or gray paint and spray it. Matt
rich-allen 10-21-2008 09:32 AM
The case came back from D&D and it didn't look a bit different than when I shipped it to them. The T56 comes with a clear paint of some kind on it. The problem is getting that clear off and then applying a different coating.
Thanks for the suggestion Matt.
Rich
