ECS Paxton Novi 2000 Tuner Kit (Lsx)
This is a ECS Paxton Novi 2000 tuner kit based off the c5 platform. It includes all the billet bracketry, the ac compressor bracket with the tensioner, and a brand new polished Novi 2000 blower headunit with an 8-rib pulley. This bolts up to the passenger side head and will work in a number of conversion cars, and I even had it bolted up in my f-body for a while (with c5 accessories for teh proper offset). You will need a c5 8-rib crank pulley from ATI to make this complete.
(If you intend to run ac, you will have to change the provided ac bracket back to a stock ac idler system or use your own stock ac bracket setup. The included bracket uses spacers instead of stock idler pulleys since I was not going to run ac with this system) I paid : 1495$ for the bracket setup from ECS 2180 for the Polished Novi 2000 headunit 90$ for the 8-rib blower pulley with keys Looking for 3200$ shipped. Everything is brand new! I go by xssive on ls1tech if you want to verify my posotive feedback (71+) https://webspace.utexas.edu/xssive/IMG_0024.JPG https://webspace.utexas.edu/xssive/IMG_0023.JPG https://webspace.utexas.edu/xssive/IMG_0022.JPG https://webspace.utexas.edu/xssive/IMG_0025.JPG |
| All times are GMT -7. The time now is 03:12 AM. |
