-   Engine (https://www.lateral-g.net/forums/forumdisplay.php?f=37)
-   -   flywheel question (https://www.lateral-g.net/forums/showthread.php?t=18213)
ttchevelle 12-27-2008 03:31 PM
flywheel question
I have a ls1 with and eagle crank,hughes hp4004 flexplate and the converter hub spacer also from hughes. I bought arp flywheel bolts but they seem to be too long. Do I have to run the crank spacer with this flywheel for a th400 converter and this set up? If so anyone have the part number? Thanks!
camcojb 12-27-2008 05:34 PM
On my tt 402 with 4L80E I used a spacer and GM flywheel; got both online from Scoggin-Dickey or similar. You do need a spacer of some sort unless the flywheel has it built in (never seen one that did).
ttchevelle 12-28-2008 08:24 AM
So the spacer bolts on after the flywheel? Do I still need to use the hughes spacer after that for the 400 converter hub?
