V/A Gen II or Gen IV sure fit?
which one should i choose for a 1969 camaro. V/A Gen II or Gen IV sure fit. What are the pros and cons of each system
We made Top 25 for 2008 in Vintage Air sales and did 95% of it with Camaro A/C systems. thats a lot of systems.
Gen IV period. The Gen 2 was back in the day a electronic control solution before the Gen IV came out. The GEN 2 is not a Camaro kit but is a universal kit and must use a different control. tThe Gen IV fits your car, uses your control, is bigger and badder and less money. That should do it. |
yep- very happy with Gen 4 no question- u need to add some goodies if you want to hide hoses etc.
Why did VA go from a Gen 2 to a Gen 4? Where's gen 3? Just curious.
Is the gen 4 available in pieces? I am looking for the evap/heatercore portion. I have the rest of the a/c system. Can you give me a ballpark of cost.
Thanks, Kory |
We can do the dash kit which is evap. contols, vent tubing, vents, etc. $750
I'd get the gen 4. I have the sure fit & i am not impressed by the quality. I saw a gen 4 and it looks like a benz compared to the pinto-like sure fit that i have. I will be using a gen 4 in my current 69 project, but i have not actually used one as of yet. Frank, if youre still on, i have no heat on my sure fit. Any ideas on things to check? This was my first install & I may have reversed the hoses or am using the wrong vacuum source for the control valve.
Scott |
| All times are GMT -7. The time now is 01:34 AM. |
