-   -   1st gen rearend and suspension (https://www.lateral-g.net/forums/showthread.php?t=18862)
camaro2nv 02-02-2009 07:39 PM
Ok so Im looking for a rear axle complete along with a suspension that will allow shockwaves. Car is tubbed and the wheels are 20x12 with a 5.5 backspace. What do you suggest?
ironworks 02-02-2009 07:43 PM
We can build whatever you need. Call me at the shop
Rodger
Silver69Camaro 02-03-2009 10:10 AM
We've had great success with our direct-fit rear clip:
http://www.artmorrison.com/albums/67...2764.sized.jpg
http://www.artmorrison.com/albums/67...2631.sized.jpg
http://images44.fotki.com/v1407/phot.../camaro-vi.jpg
Available in triangulated 4-bar and 3-link. The tri 4-bar clip requires no floor cutting whatsoever, and the three-link allows you to still retain the rear seat. Imagine being able to replace your .045" thick 2x3 frame rails with a mandrel-bend 2x4x0.120 welded assembly. Talk about a stiffness improvement! You can keep your stock fuel tank too with minitubs.
Same suspension used in our 3G Vette that turned over 1.05G on undersized tires. It works!
Mrfixit 02-03-2009 02:23 PM
Sweet!
crazycarl 02-04-2009 10:01 PM
If you're in Roseville CA, Chassisworks is right around the corner. They have a couple different options that would work for you.
camaro2nv 02-04-2009 10:05 PM
REALLY? I was really set on the AM 4 link but it would be nice to see the CW in person.
fxstdale 02-04-2009 10:25 PM
ame 4 link is the way to go
ViperBlue68 02-13-2009 01:38 PM
That looks great! VERY interested in getting this how bad is shipping to 95991? also what width is the 9" housing? I want to run 20x12s in the rear
Silver69Camaro 02-16-2009 06:08 AM
You can get pretty much any width axle housing you want. Normally for a 12" rim we recommend a 47.25" housing (housing width, not axle mount surface width) and 4.5" B.S.
Shipping is somewhere around $500 fully loaded, but don't quote me on that!
ViperBlue68 02-16-2009 03:20 PM
where are the mounting points on this setup?
