Dash blinker lights?
What are you guys using in your custom dashes for the blinker lights?
I'm finding a bunch of LED bulbs but no mounting hardware that looks like it would work. |
Just an FYI on those bezels, you can buy them at Radio Shack for a few $'s and insert any standard 5mm LED into them.
Or how about just drill tight hole and push it thru with few drops of glue ?
I used the 3mm(1/4 inch) led's that you can get at Radio Shack. They have a positive and ground wire coming off of them, pretty easy to do. They are the exact same ones as these- http://www.detroitspeed.com/productp.../leds_prod.htm
| All times are GMT -7. The time now is 06:45 AM. |
