-   EFI and Forced Induction (https://www.lateral-g.net/forums/forumdisplay.php?f=47)
-   -   6.0L LQ4 Fuel injection (https://www.lateral-g.net/forums/showthread.php?t=19026)
bowtie_nut 02-10-2009 05:23 PM
Okay fuel injection guys I have a question. I have a 99 silverado with a 6.0L factory engine. It has problems starting. The engine sounds like it is starting so I let off the ignition and it dies. Some times it will start and run fine, then I shut it off and try it again and it won't start. The check engine light never comes on at any time. I have checked the fuel regulator on the fuel rail and cleaned around the throttle body with carb cleaner. Does anyone have any ideas?
youthpastor 02-10-2009 05:36 PM
fuel pressure test? spray some carb cleaner in t-body to see if it starts- if i had to guess- fuel pump- pressure drop will cause hard - no start especially cold- if it is put an A/C Delco pump in it- not aftermarket- my 2 cents- Chris
bowtie_nut 02-10-2009 05:39 PM
when I take the intake ductwork off of the throttle body the engine dies, is this normal?
youthpastor 02-10-2009 05:43 PM
cant do that- has to run through maf sensor to stay running- i thought it wouldnt start??
bowtie_nut 02-10-2009 05:45 PM
it will start every once and a while. Once it is running it runs fine. It is just a matter of getting it to start
youthpastor 02-10-2009 05:50 PM
how old is the fuel filter?? sounds like the pump is weak- hard to start cold??
bowtie_nut 02-10-2009 05:54 PM
filter has around 5 years on it and the pump was replaced last summer.
youthpastor 02-10-2009 05:58 PM
yep start with the filter (plugged) - it should be replaced more often- check the fuel pressure- there should be a shrader valve on the fuel lines- i can look tomorrow for specs at work or google it - maybe someone can chime in here- but i think it should be all of 50psi- good luck- Chris
bowtie_nut 02-10-2009 06:00 PM
thanks for the help
WSSix 02-11-2009 05:56 AM
fuel pressure on any LSx engine which includes the iron truck engines should be 58psi at all times. The engine should crank and run with 50 psi but there's a problem if you've only got 50 psi
