1969 Camaro Parts For Sale
I bought the 1969 Camaro from Tyler at ATS and am parting a bunch of stuff from the car. We are doing a full make over on it and wont need some of the stuff. This is all new or in like new condition.
Interior: Front buckets with headrest in great condition $500pair Front doors complete $250 Rear panels $100 Dash Cluster great condition $150 Ididit steering colum $200 SOLD headliner with bows good condition $50.00 door sill plates $25 Full carpet kit black $50 http://i269.photobucket.com/albums/j...ht/Img0085.jpg http://i269.photobucket.com/albums/j...ht/Img0085.jpg http://i269.photobucket.com/albums/j...ht/Img0080.jpg http://i269.photobucket.com/albums/j...ht/Img0074.jpg Suspension: Might be sold will now in a few days all brand new SOLD ATS Tall spindles $500 SOLD Global West front upper and lower control arms with QA1 coil overs $1000 SOLD Global West L2CAT5 rear springs with Koni shocks $800 SOLD Brake System: $1500 OBO brand new condition SOLD C5 Z06 front Corvette brakes with Baer 2pc rotors C5 Zo6 rear Corvette brakes with working parking brake Wheels/Tires: $2500 wheels and tires OBO brand new SOLD Budnik Lateral 18x9 with 245/30/YR/18 Michelin tires SOLD Budnik Lateral 18x11 with 315/30/YR/18 Michelin tires SOLD http://i269.photobucket.com/albums/j...ht/Img0065.jpg http://i269.photobucket.com/albums/j...ht/Img0034.jpg Engine: Pro-systems road race style carb $400 Manifold $200 Anvil Carbon Fiber fender braces $75 SOLD |
Also have stock style front end grille $100 http://i269.photobucket.com/albums/j...ht/Img0036.jpg
http://i269.photobucket.com/albums/j...ht/Img0036.jpg http://i269.photobucket.com/albums/j...ht/Img0086.jpg http://i269.photobucket.com/albums/j...ht/Img0087.jpg http://i269.photobucket.com/albums/j...ht/Img0038.jpg |
The wiper motor is for sale $50.00
along with all the badges from the car $35 also have the rear gills for sale $25 glass but that will be a local pick up $200 Tail lights $50 Hood hinges $50 Hood $100 |
All of the suspension, wheels, brakes, tires, stuff like that have zereo miles on them. Installed but never driven on. It's also worth mentioning that those L2CAT5 springs where in the car for almost two years and it sat perfect! Good deal for some body!!
I may be willing to sell just the wheels if someone is intersted. We have not decided if we are going to put 19-inch on this year or not. If I sell the complete package we will go 19 but if not I might go 18-inch.
http://i269.photobucket.com/albums/j...ht/Img0031.jpg http://i269.photobucket.com/albums/j...ht/Img0044.jpg |
here is some info on the control arms they retail for over $1000
These arms will fit 67-69 Camaro or Firebird and 68-74 Nova / X-Bodies Upper Arms: Benefits and Features. Part # CTA-79AP No frame modifications required. Direct replacement for stock upper control arms. Built in 6 degree's of positive caster provides straight line stability. Caster also improves corner entry do to new camber curve. Upper arms reduce factory bump steer by cutting it in half. (Beneficial for both drag, street, and road racing applications). Stock Ball Joints are used. Will accept any stock style spindle. Control arms are fully assembled with billet shafts, uses Polyurethane, ball joints, and bump stops. Del-A-Lum bushings are also avaialable. Tubular arms are powder coated black. Provisions for adjustable bump stops (Drag racing). New alignment specifications are included in every kit. Control arms can be used with lowered frame holes. Upper arms will work with coilover kits. Lower Arms: Part # CTA-79LP Global West's tubular lower arms are perfect for stock or performance suspension upgrades. Both arms are supplied with ball joints, bump stops, control arm bushings, and a innovative rotating spring cushion. The cushion acts two fold by offering isolation and a proper indexing of the coil spring. Even if you trim your coil spring in order to lower the car, the lower spring cushion simply rotates for proper re-index. The control arms also provide additional header tube clearance, requires no frame modifications and are pre-assembled for your conveyance. Benefits and Features for Lower Arms: Global West's control arms are well designed providing excellent support around the spring, ball joint and bushing areas. Straps are utilized at the bushing locations while 3 tubes support the spring pocket. The sway bar mounting plate acts as a gusset strengthening the ball joint area. Incorporate our rotating spring pocket and you have an unbeatable package. The following list specifies standard features with this lower control arm. Strength: (Built out of 1 5/8 roll cage tubing ). Polyurethane bushings are used for most applications. Del-A-Lum Bushings are also available. Reinforced sway bar pick up points. Lower arm bump stops are standard. Steering bump stops are standard. Cross bar supporting spring pocket. Additional clearance is added through the middle of the arm for header tubes. Traditional Global West straps are used at bushing housing locations for strength. Control arms are powder coated black. Fully assembled when shipped. |
Here is the QA1 info retail for $450
HAL-GMP3350-1 Coil Springs/Shocks, Front, Buick/Chevy/Oldsmobile/Pontiac, Kit Description: Coil-over performance for stock GM front-ends. Coil Springs/Shocks, Front, Buick/Chevy/Oldsmobile/Pontiac, Kit Features: Adjustable Mounting Bracket Included No Adjustable Valving Yes Bushing Color Black Bushing Material Polyurethane Coil-Over Kit Position Front Coil-Over Springs Included Yes Crossmember Included No Gas Charged No Hardware Included Yes Internal Design Twin-tube Number of Valving Selections 12 Quantity Sold as a kit. Recommended Vehicle Weight (lbs) 1,701-1,900 Shock Body Finish Clear anodized Shock Body Material Aluminum Shocks Included Yes Spring Finish Silver powdercoated Spring Rate (lbs/in) 350 lbs./in. Suspension Height Adjustment Stock Welding Required No |
You need to list a price for all of the items that you're selling.
| All times are GMT -7. The time now is 10:58 AM. |
