You have to quiet down your car with a minimal loss of power...
How would you do it. What muffler combo? Borla? Magnaflow?
2 Mufflers 2 resonators? 4 Mufflers? I'm trying to prep my car for laguna seca. Their sound limits are 92 decibels and the readings are taken at 50 feet from the track apparently. I'm currently running 2 chamber flowmasters with an h-pipe, 2.5" diameter. Dumps behind the rear axle... its... loud to say the least :_paranoid |
I don't understand the problem:thumbsup: Sounds bada$$.
tailpipes would help |
and second i would bet money that you will gain power by going with a straight through design like the borlas or magnaflows over a chambered design and be quieter i prefer the sound of borlas but magnaflows are a little quieter... |
I agree. An X-Pipe and tailpipes will make a surprising difference. Resonators DO cut down on power.
The sound meter at Laguna is on the right side of the track. Make tailpipes that you can add 90 degree turns on the ends to point the exhaust to the left. Pozzi runs there and should also have tips. Sometimes even your engine makes it too loud and you might need a closed air cleaner and underhood insulation.
I have been told Flowmasters don't quiet enough at Laguna. Our 73 Camaro has a 3" X pipe then just before the mufflers we put flowmaster reducer cones from 3" to 2.5" then into the Walker 2.5" mufflers, then flowmaster mandril bent tail pipes. Even then, the car has gone over depending on conditions, so I made up some elbows for the tail pipes to divert sound to the left. We also run a 1970 Z/28 air cleaner instead of the usual open element one. It costs 10 RWHP though.
The car sounds very quiet on the track, like a stocker almost. I think the Laguna DB limit is BELOW what the state of California requires. :mad: Here is mary in the red camaro at Laguna. http://i117.photobucket.com/albums/o...aSecaDec06.jpg |
That sounds as quiet or more so than OEM.
holy neg camber batman, david how much neg camber do you run at laguna? -3.0?
Jake,
No we run -1 deg on Mary's Camaro. It might be 1.25 now, I don't remember. David Here's a better shot showing camber. http://i117.photobucket.com/albums/o...itlane1208.jpg |
I saw this info and was not amused. Quietest performance mufflers: 1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT. 2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT. 3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT. 4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT. 5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT. 6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT. 7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT. 8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT. 9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT. 10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db). 11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT. 12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT. 13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT. 14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT. 15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT. I'm thinking about just having an extra set thrown on to see how quiet I can get it. Damn laguna's neighbors :( |
| All times are GMT -7. The time now is 04:52 PM. |
