-   Lateral-G Sponsor News: Sales, New Product Info (https://www.lateral-g.net/forums/forumdisplay.php?f=43)
-   -   New product - hydroboost PS tank and reservoirs (https://www.lateral-g.net/forums/showthread.php?t=19569)
Musclerodz 03-08-2009 11:33 PM
3 Attachment(s)
Musclerodz is proud to introduce its first in a line of exclusive manufactured parts. Tank has been designed specifically for use with Hydroboost systems. These are not a simple tank to hold fluid. There is over a dozen parts to these tanks, many to control the flow of fluid. Outlet is a -10 (-8 optional but not recommended), dual returns are -6, internal baffling to prevent any aeriated fluid from entering the system. Cap is vented and baffled as well. Machined clamps are also being made and will be optional at extra cost, as well as braided supply and 1 return line to match the braided lines supplied with Hydratech systems. Prototype tanks are done and going out to a select few people for field testing and feedback. First run of tanks should be available 4-6 weeks. Price point has not been finalized but should be around $150. These tanks will also be available for non-hydroboost setup as well.
In addition to the power steering tanks, we will also have matching overflow/recovery tanks as well. Price point on those will be closer to $100, but not finalized either. Several different finish options are planned, machined, polished, and annodized.
These tanks are just the first of several parts we plan to release. Stay tuned!
bigtyme1 03-09-2009 04:00 AM
they look good mike.
ElkyZO6 03-09-2009 06:15 AM
That looks awesome.:thumbsup:
camcojb 03-09-2009 07:38 AM
I may have to get one of those. I have a hydroboost and just swapped to a remote reservoir pump because the integral reservoir pump is too small, not enough fluid capacity. I have a remote aluminum tank that came on my car originally, but it's not really set up for hydroboost, would have to add another fitting, etc.
Good job Mike.
Musclerodz 03-09-2009 09:12 AM
Good job Mike.
That is a common problem we have found. There are some tanks out there, but nothing that looks nice or has a matching overflow tank. All hydroboost systems could benefit from running remote reservoirs for the added capacity to help prevent cavatation, and with a properly designed tank with 2 returns, eliminate the issues that are caused by teeing in the return lines.
Datsbad 03-14-2009 09:36 PM
Nice tank, Might have to try one.
We have been running Moroso tanks
DRJDVM's '69 03-14-2009 10:35 PM
Mike
Perfect timing.... I'm just starting to look for a PS and rad overflow tank and wanted to get a matching set for each side of my radiator....count me in.....please keep me posted
Ned
V8TV 03-15-2009 06:30 PM
Great idea Mike! Solves problems and looks cool.
Musclerodz 03-16-2009 09:21 AM
Prototypes are shipping today or tommorrow. I plan to start a short production run so I can finalize pricing a week or two after I get some feedback and any necessary changes we might need to make.
DRJDVM's '69 03-16-2009 11:15 AM
Hey Mike
Do you have specs on their size etc ? I'm researching what will fit in the space next to my radiator.
Ned
