-   -   4.8/5.3 Heads, Block, Trans (https://www.lateral-g.net/forums/showthread.php?t=19664)
carkrazy1987 03-14-2009 04:34 PM
I have a pair of 4.8/5.3 head in good condition. the heads are 862 casting, and were on a 4.8 thats spun a bearing. cylinder heads had been replaced recently before the bearings spun. cylinder heads have aprox 20k miles. heads come complete with stock rockers, pushrods and valve covers if you want em. Asking $200 obo + Shipping for the pair.
Also i have said 4.8 block. its in short block for right now. the crank and 2 connecting rods are ruined. so block is good, 6 rods are good, 8 pistons good and cam still in engine. $100 obo. Prefer local pickup.
I have a chevy th350c built with shift kit and 2000 stall. Transmission was rebuilt recently, new forward clutch drum, all new friction materials and plates and what not, B&M shift kit installed at the same time. i bought a brand new hughes performance torque converter with a 2000 rpm stall. everything has about 100mi on it. i took my car off the road and converting to manual. everything new, out of the car and ready to go. $1000 invested. Part numbers and price of items when i bough em from summit.
Converter - HUP-GM20L $294.95
Trans Rebuild Kit - BMM-30229 $232.95
Trans Shift Kit - BMM-30235 $69.95
Trans Rebuild Labor - $400.00
also have a 168 tooth flywheel for 1 piece rear main seal for sbc put on at the same time also available with trans if wanted.
I'm asking $400 obo for trans assembly
http://i281.photobucket.com/albums/k...r/102_1888.jpg
http://i281.photobucket.com/albums/k...r/102_1891.jpg
http://i281.photobucket.com/albums/k...r/102_1892.jpg
http://i281.photobucket.com/albums/k...r/102_1895.jpg
