-   -   Gear Vendors Overdrive for a th400 (https://www.lateral-g.net/forums/showthread.php?t=19717)
indebt69 03-17-2009 03:40 PM
its Sold
indebt69 03-19-2009 08:52 PM
Bump!!! This unit is 8 years old. I called Gear Vendors today and gave them a serial number on it. Nothing has changed though since then. Same great unit. $1500 shipped
DaCajun 03-21-2009 12:12 PM
I installed one of these on my 2002 F350 7.3 4x4 dually with 4:10 's and let me say it was the best $3000 I've ever spent. In double overdrive my one ton truck gets 23 to 24 mpg at 80mph and all your hear is wind noise. At 80 mph the 7.3 is turning just under 2k rpms. Keep in mind these overdirves can be installed on other trans than just a turbo 400. I am not associated with the seller, I just thought I'd share my experience with a gear vendor overdrive. At $1600 this is a deal....
-Dave
66zz430 03-22-2009 08:01 PM
Any pics.
I need to call to see what's needed to run it on a th350?
DaCajun 03-23-2009 11:16 AM
If this helps any. I originally purchased my GV for my 3/4 ton 6.5 tubo diesel 4x4 truck. I sold the truck but took the GV out cus I like it so much. I bought the Ford 1 ton Superduty 4x4 called Gear Vendors and they swaped out the 4L80e adapter for the adapter needed to installed the GV on my Superduty for a small fee. I must say, Gear Vendors was extremely helpfull with this swap. Hope this helps....
-Dave
Jr 03-23-2009 01:07 PM
Darren,
Do you have the electronics for the GV unit? If so, we need to talk.
David
indebt69 03-23-2009 10:35 PM
David,
Yes, I have everything you would need to drop this in your car and go. If anyone has a question, please feel free to ask.
The unit is about 8 years old and then I bought directly from Gear Vendors the following new parts which haven't been opened:
14" speedo cable extension
Slip yoke
Wiring Kit for gear driven speedometer
Seal for th400/4L80E
Gasket, nut and shim kit.
Originally Posted by DJW32 (Post 203360)
Darren,
David
indebt69 03-23-2009 10:40 PM
Thanks for the kind words Dave. Gear Vendors name speaks for itself and very rarely do you see used units for sale. Yes, i can take pics and I'll try to get some up tomorrow. Thanks:thumbsup:
-Dave
