-   -   Camaro w hotchkis leafs - one wheel off the ground in a driveway? (https://www.lateral-g.net/forums/showthread.php?t=19832)
rogue 03-23-2009 04:51 PM
Quick question for you all.
I'm running Hotchkis subframe connectors, rear lowering leafs and QA1 shocks dialed to the softest setting.
When I pull into a semi-steep driveway at an angle one rear wheel will lift up off the ground and spin a bit. Is this normal for a camaro with a properly stiff chassis or are my leafs not installed correctly. Yes I do have posi.
The rear suspension does seem pretty stiff on the highway, not rock hard but definitely firm. Car does great on the track so maybe its normal?
Just a random thought I figured I'd ask about.
Steve1968LS2 03-23-2009 05:41 PM
did you tighten down the shakles with the car up on a lift? If so they might be in bind.
With the weight on the wheels loosen the shackles and re-tighten them with the suspension loaded.
Just an idea.
mpozziCPL 03-23-2009 06:27 PM
Yes, pretty much normal ...
Cheers,
Mary Pozzi
Steve1968LS2 03-23-2009 06:40 PM
Cheers,
Mary Pozzi
You guys with your wacky leaf springs... :_paranoid
rogue 03-24-2009 10:03 AM
Better watch it, Mary might have to start making Penny look bad with those leaf springs of hers :lol:
Cheers,
Mary Pozzi
Thanks :thumbsup:
Steve1968LS2 03-24-2009 04:30 PM
Mary could make me look bad in a Yugo.. lol
Her time at the Costa Mesa autocross was tied for best old car with the DSE second gen.
