-   Transmission and Rear End (https://www.lateral-g.net/forums/forumdisplay.php?f=39)
-   -   rear axle vent leaks-please help. (https://www.lateral-g.net/forums/showthread.php?t=20016)
jkcamro67 03-31-2009 09:35 PM
I have a 1967 camaro with a 9" rear end. I run Red Line gear oil. I noticed that the axle housing vent was leaking. I added about 16" of hose upward and put the vent at the end of the hose. I noticed that the vent still leaks. I dont know what would cause it or how to fix it. I filled the rear end to the bottom of the fill plug so I dont think it could be overfilled. I dont know what would cause it to fill up the vent line and leak out. Any help would be great. Thanks.
Tiger 04-01-2009 05:59 AM
Hey
where is the vent, can you reposition it? it seems like the oil is being pushed into it in some way.
AJSZR2326 04-02-2009 08:32 AM
try replacing the vent, i beleive its there to let air in only so maybe its plugged up and not working properly, kinda like a pcv valve.
