-   -   ATS Engine Plates LSX F/S (https://www.lateral-g.net/forums/showthread.php?t=20091)
brans72 04-04-2009 04:09 PM
I have a set of used ATS LSX Engine Plates for sale( $113.00 includes shipping). I installed them on my engine and the header won't clear due to edelbrock headers. These where made for Camaro's not Chevelles so my lost and your gain. This is for Plate only No eninge mount!!! I will be taking them off Tuesday night. Thanks Brandon
By the way I have talked to Tyler and many other people out there and only way to fix my problem correctly without highly moding th car more is switching engine plate. This plate was made for Camaro according to Tyler and I do wanna say Tyler has been very helpful in all question and makes very nice pieces!!!!!!! Thanks again Tyler for always anwser my questions and thinking one step ahead. Brandon
Z06vette 04-04-2009 05:08 PM
Do you know if these will work with a Wayne Due subframe? It has a 6 speed crossmember already on it (i'm running LS1/T56) If so I am interested.
[email protected]
brans72 04-04-2009 06:09 PM
Scott I do not know for sure I would recomm asking around or ask Tyler hisself,as I do not wanna steer you in the wrong direction. I could call Tyler Monday and check with him if you want. Brandon
130fe 04-05-2009 06:08 AM
Brans72, just curious why you didn't use the edelbrock plates? I am considering the edelbrock setup but haven't found any pictures. Post some up if you have them. Bump for you.
camcojb 04-05-2009 08:15 AM
Originally Posted by brans72 (Post 205911)
I have a set of used ATS LSX Engine Plates for sale( $113.00 includes shipping). These where made for Camaro's not Chevelles so my lost and your gain.
I used those plates on my Chevelle, no problems. The urethane mounts have a tab that gets in the way with the Chevelle frame pad, so you either flip the mounts/plates from side to side (makes them upside down but they work perfect), or you trim that tab. Either way, the plates work fine, it's the design of the motor mount itself that causes a very minor issue that is easily corrected.
brans72 04-05-2009 08:16 AM
At the time they did not make a plate or header so I went with ATS. I can take some pics this week for you and pm them to you.
130fe 04-05-2009 08:51 AM
Cool, thanks would appreciate them.
brans72 04-05-2009 01:53 PM
Jody I flipped the side to side every way possible and will not work with my setup in my 1972 chevelle. Sure it would work if I moved my engine back redrilled holes or cut my header up and rewelded it but I am going to do neither and go the route Andrew did on his GTO. I will be First to say I like material and look much better from ATS then Edelbrock but sometimes you can't have the cake (your choice of flavor) and eat it to.
