DSE mini tub question?
Are the dse mini tubs compatible with a stock gas tank?
Stock tank is anot a issue for the mini tubs. What suspension you run and what exhaust you want to run may require notching ir narrowing the tank.. If you run leaf springs, you will need to narrow the tank, a 4 link and want tailpipes, you will want to notch / dogear the forward corners of the tank.
| All times are GMT -7. The time now is 07:35 AM. |
