A-Body Lowering ??? School me....
I'm trying to do some homework on lowering my 1970 Buick Skylark. I'm not too familiar with the geometry of lowering w/ consideration to weight of the car and performance. Skylarks weigh about 3400 to 3500lbs like most chevelles. Can anyone offer some suggestions to a nice suspension setup, ride height and wheel/tire combo that works for an A-Body too handles daily driving very well??.....Thanks....
Thats easy......you can either cut your existing coils or order drop springs and cut them to desired height! 18's are no problem! |
Also, 500 lb/in is actually pretty darn soft on these cars. I was running 550 lb/in on my small block which was *too* soft. I'm now running 625 lb/in springs, and they're still too soft; I'm going to step up to 750 or 800 lb/in and see how they feel. The ride with the 625 lb/in springs is firm but not jarring, but they're still too soft and the car "porpoises" a bit on fast right/left transitions. If you aren't abusing the car in the corners they're just fine, and probably a little bit firm by many people's definition, but they certainly do not provide a harsh ride. Pairing them with decent shocks is also very important, a lot of cheaper shocks out there don't have adequate rebound control. If you're just going to cruise the car with some occasional spirited turns and want good smooth road manners, I would suggest running about 500-550 lb/in springs for a SB car. I can't comment on good spring rates for a BB car. Rear spring rates between 150-175 lb/in are where the A-bodies seem to function best. Also, an easy way to lower the car and also be able to adjust your height WITHOUT cutting coils is to hit up a circle track supplier and buy Afco spring jacks that sit up in the frame and then use Afco springs. You can get the springs in a wide variety of rates (cheaply, too) and then adjust the height via the springjacks. Troy |
I don't have them installed yet, but I went with AFCO 5"x9.5" 700lb springs, and the taller height adjusters from speedway.
It may be too stiff, it might not be... I won't know until it's together and I'm driving it.
I'll post a full testimonial in June when I get back from driving it from Rochester, MN to Nashville, TN with the wife for our honeymoon. A little vibration might be a good thing :unibrow: :D I will be running solid bushings in front with 700# springs and a small (if any) sway bar, and spherical bearings in the rear with 175# springs and no sway-bar. I'm currently driving on stock springs with big sway-bars and it handles OK, but not great. The ride way too stiff in the rear from the poly-bushings in the quadra-bind C4L. I'm actually anticipating a smoother feel, the bumps will feel sharper, but not as big. |
Camino, if you are going to post technical spec or pretend to speak tech jargon you must first learn a little bit about what you are speaking of. Spring rate is calculated using number of active coils, wire diameter, and mean diameter. Free height never factors in to rate. As already stated, springs are rated in lbs. in.; not psi. 500lbs is pretty weak for most cars, even factory springs in newer cars are over the 500lbs. in. mark as manufactures have figured out that heavy rates do not equal harsh ride. I run a 750/175 combo and am going to up to 1000lbs. in the fronts (yes, I drive it everyday on city streets). Lastly, the two schools are not light springs/big bars and big springs/big bars, they are light springs/big bars and big springs/light bars. Derek, you are going to need at least a 7/8" bar up front, the 700# just aren't enough by themselves. |
I outta here. Go blow smoke up someone elses ass.
| All times are GMT -7. The time now is 12:13 AM. |
