DSE coilover modified subframe, 1st gen
SOLD SOLD SOLD
Stock 68 subframe with DSE coilover kit installed, with the following: DSE coilover kit installed & welds cleaned up on most of the frame DSE Koni coilover shocks & springs (currently 650s) DSE Upper control arms DSE lower control arms Stock spindles (completely cleaned & repainted) Hotchkis hollow swaybar $2850 plus shipping. The frame will be resprayed in chassis black before shipping, so you get a nice clean frame to install. The UCAs & LCAs are new & have just been mounted for fittment (vey minor scratches, if any). The coilovers and springs have never even been out of the box from DSE. The frame is located at Jake's RodShop in Bridgton, Maine. As for shipping, we can work something out. No pics right now, as the frame is waiting for a buyer to decide what he wants...then we'll squirt it. Since Jake sells frames & ships them, you can be assured that your frame will not be shipped strapped to 4 tires! I have lots of other parts that can be added on to form many different combos: (all parts listed below are new as well) 1. ATS short spindles (recommended by Tyler @ ATS and DSE) 2. Wilwood SL6 front brake kit for stock spindles 3. Touring Classics C5/C4 hybrid kit (stock spindles) that allow you to use TTIIs and many other 17" standard hoop wheels 4. DSE steering box (600), ceramic coated 5. Unisteer rack and pinion kit 6. The set of adjustable QA1 coilovers and spring that came with the frame (550s) Contact me via PM or email at hartjeff AT comcast DOT net JEFF |
PM Sent
The DSE steering box would come with the rag joint, and the appropriate fittings.
As of now, I'd like to leave the buyer's options open, but all the parts are for sale at this point. Jeff |
subframe
very interested do you have any pics? if so email me at [email protected]
Jess-
If no one wants the box with the sub, I'll let it go for $525. Rag joint + fittings will run an extra $75. lsb- I'll take some pics, but be warned- right now it's just a painted frame with the UCAs/LCAs taken off to protect them. What exactly are you interested in, the frame without any 'options'? |
Jeff, too bad you don't have the sub at the house, I would have been there this afternoon, damn, Steve
Sub
That could be arranged! We can cut you a sweet deal on shipping brother...let me know what you want, as a bunch of the 'other parts' are down in FL.
Parts
OK- I've had several PMs about the DSE box & ATS spindles; the DSE box & rag joint (with fittings) are 525 + 75 respectively. The ATS short spindles are $600. First one to get me $$$ gets them.
| All times are GMT -7. The time now is 10:32 AM. |
