Fixing the paint in the trunk question
How should I go about fixing this? It came about when I took the trunk mat out because I was told moisture gets trapped under it and causes the trunk to rot. Well quickly after taking the mat out it ended up looking like this:
http://img.photobucket.com/albums/v4...s/IMG_2247.jpg What would be the best way of tackling this? Thanks! |
I'm not an expert, but this is what I would do:
1: Make sure it's just surface rust, if it's not, you will need to replace some sheet metal. 2: Use a grinder with a wire brush attachment to remove the surface rust. 3: Coat with a product like por15, Rustbullet, Zerorust, etc. :thumbsup: |
Thanks, appreciate it. :thumbsup:
| All times are GMT -7. The time now is 01:50 AM. |
