214Chevy |
06-28-2009 11:34 PM |
BBC Fuel Injection Intake
Hello all! Up for sale is a BBC fuel injection rectangular port intake unit. I was going to have this unit chromed by Mark @ Street & Performance in Arkansas and put it on a 540 or a 582 c.i. engine. But, we all know how our projects can and will take twists and turns. I purchased this in December '08 from Jim @ Arizona Speed and Marine. Nonetheless, I no longer need this as I am putting an LS1 into my '72Chevelle. This unit comes with billet fuel rails hidden between the upper & lower plenums, billet 1300 cfm monoblade throttle body and Aeromotive billet adjustable fuel regulator. Sensors included are....MAP, TPS, IAC, water temp and air temp. This unit employs the same principle as Chevy's BBC Ramjet 502 but with better airflow and larger runners. It is not ported because I didn't know what BBC heads I was going to use. But, Jim did port match the mouth on it to get better airflow from the monoblade throttle body. NO INJECTORS OR WIRING HARNESS. No injectors because I wasn't sure what #lb I needed until I knew if I was going to get a 540 or a 582. No wiring harness because I sent it back to Jeg's in exchange for the LS1 harness. I repeat.....NO INJECTORS OR WIRING HARNESS. This unit costs $2400 new.
It can be yours for $1400
SOLD!!!!!!!!!!! ... (finally):rofl: :rofl:
