Hyd to Solid cam conversion
Hi guys, I need some help.
I want to buy a new mechanic cam for my sbc 350 engine. Right now it has a Crane Cam with rpm range of 2800-6200 (284H it´s the part number if i´m not wrong). Wanted to step up to a solid with of 3000-7000 aprox. but I need to be sure in first place of the considerations for the engine. Heres my questions, hope you can help me: - Is it really necessary to plug studs in the heads? - Stronger or shorter pushrods are needed? Thats all for now, I accept any sugestion and comments. Thanks a lot guys. Bye! |
screw in studs and guide plates should be used and different length pushrods may be needed. You will need to check those and the valve springs to make sure they are correct for the cam.
Good luck! |
You have several things to check - buy - etc before you just stick a new stick in there.... You need to be concerned with whether or not the springs you have will work with the new cam (spring rate AND size) -- You'll need a push rod length checking tool -- Screw in studs - guide plates if you don't already have them and on and on. Let's not even get into the match up of whether or not your HEADS are capable of delivering the air you need at the lift your cam makes (which might already be an issue...) I have to ask though -- if your cam is already capable of spinning to 6800 -- what do you think the new cam is going to do for you when it's range is only 7000... What don't you like about your current set up? Why the change? Have you considered the entire car as a whole? The weight of the car - the size of the motor - the gear ratios - the tire size - the convertor stall (if you have an automatic). The cam you're talking about is what I'd consider a full out DRAG race piece... Driving on the street with that beast would be a horrible experience in my opinion. It would have zero bottom end torque... Tell us about your car... what you're plans are for it... gears - tires - heads - use etc and maybe some of the 'boys' here can help you get to where you want to go with it. Just my .02 worth.. LOL |
Thanks for explaining that Greg. I forget to add the details sometimes. Other times I can't seem to shut up to save my life.:lol:
my only point if your going from a hydraulic roller to solid roller is to make sure you get a stud girdle and a rev kit. you're gonna find your valvetrain comes out of adjustment pretty frequently with a solid roller, and a good stud girdle will help keep things where they need to be.
and the rev kit is more of a safety to keep you from floating a valve if your planning on revving it up higher. just my 2 cents! i'm sure someone with more experience will chime in and correct any mistakes i may have made with my comment. |
:lol: Totally!! I can't shut up either -- and type pretty fast too... sometimes - more often than not - faster than my brain works. This post sounded like a young gun - that might need a bit more 'info' and food for thought than just the intial question. I think many of us 'been there done that' types take some of this stuff for granted. We alreay know what a big azz cam does/doesn't do... like the old 750 cfm holley on a 265... back in high school... the guy with the stock factory motor - that knew what a timing curve was - always kicked our butts! All he did was re-curve his distributor - while we drowned ourselves in FAT A/F ratios... I still love the guys that do a big bumpstick in a 9:1 motor -- and can't figure out why it's just a big lumpy TURD... and when I ask them what their cylinder pressure is - they quote the static compression ratio... If they're nice -- I have them come to my house and we do a cylinder pressure check - then I explain cylinder pressure - valve overlap - right sizing a cam to match the heads - and that the 1050 holley they're running isn't helping them either! Oh - and don't get me started on the guys that stick in a brand new MSD distributor - and leave the garage door springs it came with, on it... and the stock stop bushing... Oh god... I chuckle at that one everytime. |
I think you may have mistaken the intent of my comments... they were meant to be "things we've all done..." and that there is MUCH to learn when dealing with cars etc. |
oh.. i know your intent was all good or otherwise you wouldnt have posted! i wasnt trying to call you a know it all! haha..
It took me 35 years to finally figure out there was a relationship between a cam and the heads!! LOL :cheers: |
| All times are GMT -7. The time now is 12:22 AM. |
