-   -   800 miles complete 383 with acesories (https://www.lateral-g.net/forums/showthread.php?t=21926)
sacarguy 07-31-2009 12:26 PM
383 chevy stroker
was built by kotzur racing and all parts used were brand new with the exception of the block.
Internaly balanced
new balancer
new flex plate
new cast stell crank < 600 horsepower >
new I steel beam rods < 600 horsepower >
new hyper pistons < 125 nos max >
10.5-1 compresion
arp head bolts
arp main bolts
new hi torque mini starter
new aluminum rhs cylinder heads ported by kotzur racing
comp cams pushrods
comp cams timing set
comp cams mutha thumper hydraulic cam
high rise dual plane intake new
new black wrinkle timing cover valve covers and air cleaner
new barry grant 825 double pumper carb
new aluminum water pump
new march brackets for alternator and power steerring
new one wire 110 amp polished alternator
new oil pan
new pickup
new lokar oil dip stick
new long tube headers for 69 camaro ceramic coated
msd digital ecurve distributor
I built this as a easy driveable motor on pump gas that would sound roudy but run perfect and drive great.
just run power to the distribtor and hook up the starter fuel line and alternator and you are done.
ran mid twelves in my camaro all day on radials with a turbo 350 and a 2800 converter.
It runs perfect i just decided to go big block for my 69 camaro.
asking 4000.00 turn key OBO.
if you add the parts up i have almost 8500 in the engine with all the extra parts and its got less then 1000 miles < can prove by the odometer on the brand new speedo >
here is a pic of the engine.
http://i76.photobucket.com/albums/j1...o/DSCN0342.jpg
http://i76.photobucket.com/albums/j1...o/DSCN0348.jpg
http://i76.photobucket.com/albums/j1...o/DSCN0349.jpg
wiedemab 07-31-2009 12:36 PM
Location?
or did I miss it?
daytonayellaz 07-31-2009 08:06 PM
Where are you located???
sacarguy 08-01-2009 01:18 PM
san antonio texas 78217
I am sorry its in my profile but I am located in san antonio texas and i can ship the engine frieght and split the frieght with the buyer if purchased at the advertised price.
