-   Transmission and Rear End (https://www.lateral-g.net/forums/forumdisplay.php?f=39)
-   -   tko 600 pilot bearing (https://www.lateral-g.net/forums/showthread.php?t=21974)
tellyv 08-04-2009 09:51 AM
hey guys a bought a tko 600 set up for a ls motor used this winter it came complete but I need a different pilot bearing the stock ls's i.d. (shaft size) is to small, the o.d. of the stock ls beaing is 1.704'' 43.3mm and I need a shaft size of .667'' 16.96 mm, I can't find a bearing that works. I know I can get a sleeve made but I'd rather just get the right bearing any help would be great, thanks telly
never mind I just made a sleeve!!!!
Sideshow 08-07-2009 12:33 PM
call these guys: http://www.classicchevy5speed.com/
they are really helpful even if you didn't buy it from them.
