-   -   Brand New CPP MCPV-1 for sale (https://www.lateral-g.net/forums/showthread.php?t=22260)
The WidowMaker 08-20-2009 09:19 PM
Brand new in the box, never mounted, never filled, just admired. highly polished finish..... $175 shipped to your door, if youre in the lower 48 that is.
see my other ad for chevelle parts.......
Tim
The WidowMaker 08-22-2009 09:26 AM
possible sale.......
The WidowMaker 08-25-2009 09:38 AM
heres a pic
http://www.classicperform.com/NewPro.../CP31500-C.jpg
and some answers to questions i have been getting.
"The MCPV-1 has two circuits...front and rear. The front circuit of the MCPV-1 contains the metering valve, which is required on cars that have disc brakes on the front wheels and drum brakes on the rear wheels. The metering valve does not allow any pressure to the disc brakes until a threshold pressure has been reached. The threshold pressure is low compared to the maximum pressure in the braking system, so the drum brakes just barely engage before the disc brakes kick in. Having the rear brakes engage before the front brakes provides a lot more stability during braking. Applying the rear brakes first helps keep the car in a straight line. "
"The rear circuit of the MCPV-1 contains the adjustable proportioning valve and the maximum rear pressure adjustment. The adjustable proportioning valve controls the balance of pressure between the front and rear brakes. For example, if the adjustable proportioning valve was set to 70 percent and the brake pressure was 1000psi, the front brake would get 1000psi and the rear brakes would get 700psi, regardless of what type of brakes a car has. The Maximum Rear Pressure Adjustment controls the maximum rear pressure allowed to the rear brakes to help prevent rear wheel lock up. If the Max Rear Pressure Adjustment is set to 500psi and the adjustable valve set at 70 percent, the front brakes get 30 percent more until the rear reaches 500psi."
thanks, Tim
The WidowMaker 08-26-2009 08:29 PM
sale pending
