-   -   FOR SALE: A-body frt & rear suspension (https://www.lateral-g.net/forums/showthread.php?t=22567)
BobB66SS 09-08-2009 02:27 PM
F/S: A-body Baer brakes / drop spindles / bearing hubs
See below for revised ad.
BobB66SS 09-14-2009 05:43 PM
Add'l parts sold: front sway bar, Hotchkis boxed rear trailing arms.
BobB66SS 09-16-2009 05:46 AM
Spindle/hub/caliper bracket assemblies, stock front LCAs, and stock rr upper trailing arms still available.
BobB66SS 09-17-2009 08:29 AM
I've been asked by some folks if I'm willing to separate the spindle/hub/caliper bracket components. So as requested:
Belltech 2" drop B-body tall spindles with integral steer arms; Baer bearing hubs (5 x 4-3/4 Chevy bolt pattern); and brackets for Baer Track System PBR calipers -- $400 for pair as assemblies.
Spindles -- $150 for pair.
Bearing hubs -- $185 for pair.
Caliper brackets -- $90 for pair.
Thanks again.
BobB66SS 09-21-2009 06:16 AM
Bump. Would like to clear some garage space.
Thanks again.
BobB66SS 09-28-2009 08:15 AM
Bump to move remaining components below. Prices noted are about half of what they cost new; reasonable offers considered as well.
Belltech 2" drop B-body tall spindles with integral steer arms; includes Baer bearing hubs (5 x 4-3/4 Chevy bolt pattern) and brackets for Baer Track System PBR calipers -- $400 for pair as assemblies. Prices for individual components are below.
Also have following stock components:
Stock front lower control arms -- $145 pair.
Stock upper rear trailing arms -- $85 pair.
BobB66SS 10-04-2009 05:15 PM
Add'l info -- according to Baer, the spindle is from an early '80s B-body that they used to get from Belltech and then modify to fit the Baer caliper bracket and larger rotor. Since A-body-specific spindles are now available they don't have to go thru those modifications any longer. But they will fit any 64-72 A-body and worked great on my car since 2003.
Reasonable offers definitely considered.
