-   Paint and Body (https://www.lateral-g.net/forums/forumdisplay.php?f=52)
-   -   painting sub frame (por-15) how much do I need (https://www.lateral-g.net/forums/showthread.php?t=22628)
Moose 09-13-2009 09:28 AM
Getting ready to paint my front sub frame and was wondering how much por -15 i need to order? dont want to end up with a bunch left over, but dont want to come up short..
anyone have any idea?
ZZ3ElCamino 09-13-2009 10:04 AM
Just a thought, if you order extra you can always use it inside you doors to prevent any unwanted rust.....
rjsjea 09-13-2009 10:51 AM
It is covered with rust? Just curious why you want to use that stuff? I have used it several times (brushed/sprayed over surface rust and clean metal) and had adhesion probs.
If it's removed from the car a sandblasting and prime/paint will look way better.
I bet two quarts would be more than enough POR15, to answer your question
Moose 09-15-2009 05:58 AM
No its not covered in rust. Its just has certain spots. 90 % is painted with the paint flacking in certain spots. I've sanded down all the spots I think will give me trouble.
1badchevelle 09-15-2009 08:27 AM
I just did a hole frame rear end and floor pans with 1 1/2 quarts.
So I would say get a 1 quart and you will be set for a front sub.:thumbsup:
Oh yeh your finish product will be based on your prep time.
tellyv 09-15-2009 08:47 AM
I agree, I would use an epoxy primer and something like imron, they make and industrial grade imron that is cheap and its way better than por 15, I also had adhesion problems and frankly their semi gloss looks like hell!
speedjohnston 09-15-2009 01:30 PM
I agree with the semi gloss looking like hell. Its about as shiny as the black but has flat black spots in it... its weird. I would just stick to the gloss black. POR15 does not stick to other paint. It bonds to light surface rust, and if its bare metal you need POR15 metal prep. I think it leaves behind a zinc coating for it to bond to.
As allready mentioned, take the time to do the proper prep and it will be fine. Don't do it if its humid out because it actually dries faster in humidity and won't level out as well if you brush it on.
I just applied it to my cage after using the marine clean, then the metal ready and it seems pretty tough. The shop that did the cage put some POR 15 on top of some other paint in another spot and it peeled off with the painters masking tape. The parts of the cage I prepped, nothing came off even though I was scratching at it with my nails to take the tape off.
Thats my 2 cents after using it this summer. Good Luck!
speedjohnston 09-15-2009 01:34 PM
Oh yeah... as far as amount, I have a jungle gym roll cage and about half a quart did 2 coats in the whole interior. A little goes a long way.
