khoult |
09-16-2009 02:25 PM |
Lt1
1 Attachment(s)
I have a ’97 Camaro lt1 engine with fewer than 45k miles. The engine is being removed from a 69 Camaro. The intake and accessory brackets are power-coated satin black. The fuel rail is polished with new fuel injectors. It has a new Accel Opti-Spark distributor http://www.accel-ignition.com/Default.aspx with new Street and Performance wire, wire separators, and spark plugs. The headers are Street and Performance http://www.hotrodlane.cc/ shorts and ceramic coated. All accessory pulleys, sensors, starter, and water pump are new. The alternator and air compressor is polished. The air compressor bracket is power-coated stain black and is from bowers rod shop http://www.bowersrodshop.com/home.htm . The engine also comes with a custom made engine harness made by Dr. K’s Fuel Injection and Wiring. This engine is ready to be installed. Asking $2500. Alabama
